Steering tie rod inner ball joint lock washers
lowact
#1 Steering tie rod inner ball joint lock washers
Post by lowact » Sun Jan 12, 2020 7:27 am
Help pls? Tie rod inner ball joint has two lock washers, one is P/N 12019, the other not sold separately (with critical thickness), both now seemingly "not available". Can anyone suggest a possible source? Thx.
Bob.
#2 Re: Steering tie rod inner ball joint lock washers
Post by Bob. » Sun Jan 12, 2020 12:48 pm
Hi Colin,
Triumph fitted a version of the same Adwest POWR-A-RAK unit used on the S3 to the Stag. Rimmers list both tab washers here https://rimmerbros.com/Item--i-GRID005304. Scroll down to find as they are not shown in the assembly picture. With luck could be the same size.
Bob
PS Just had a look at the S2 power steering parts diagram and it lists the 3 eared tab washer not shown in the S3 Parts Manual, as "C15408 Tab Washer Locking Housing". This is available from SNGB.
Bob
'71 S3
lowact
#3 Re: Steering tie rod inner ball joint lock washers
Post by lowact » Sun Jan 12, 2020 2:05 pm
Thanks Bob, very much.
Parts are ordered.
