Weeping Thermostat Housing
SESH
#1 Weeping Thermostat Housing
Post by SESH » Mon Feb 10, 2020 3:38 pm
The nearside thermostat housing on my series 3 is weeping. On start up there is smoke coming from the nearside housing and area under the front Carb. Once hot the smoke stops, it is water/coolant as I can smell that sweet smell of antifreeze. I am assuming that once hot and the thermostat is open, with pressure reduced, the leak stops. I have ordered a new gasket and three retaining screws/bolts and washers. In addition I have ordered some Blue Hylomar gasket sealant. Has anyone used this before. How much do you use and do you use it on both sides of the gasket.
Mike
1973 Jaguar E Type Series 3 OTS Signal Red
1968 Proteus Jaguar C Type Ecurie Ecosse Flag Blue
1963 Triumph TR4 Signal Red
2020 Mustang Bullitt Highland Green
#2 Re: Weeping Thermostat Housing
Post by mgcjag » Mon Feb 10, 2020 5:03 pm
Hi Mike....thin smear both sides of gasket....can be applied to all mating surfaces if needs be....Steve
SESH
#3 Re: Weeping Thermostat Housing
Post by SESH » Mon Feb 10, 2020 5:16 pm
Thanks Steve, much appreciated.
Mike
Neil Duke
#4 Re: Weeping Thermostat Housing
Post by Neil Duke » Mon Feb 17, 2020 9:08 am
Blue is available as an aerosol,hang the gaskets on thin wires,& spray a thin coat.
69 S2 2+2
07 Vanquish S
07 Vantage Roadster
65 Austin Healey 3000
66 Scimitar Coupe
He who dies with the most toys wins.
SESH
#5 Re: Weeping Thermostat Housing
Post by SESH » Mon Feb 17, 2020 11:45 am
Thanks for the tip Neil.
However, I now have a tube of the paste.
But good to know it's available as an aerosol.
Mike
