#1 Weeping Thermostat Housing
Posted: Mon Feb 10, 2020 3:38 pm
by SESH
The nearside thermostat housing on my series 3 is weeping. On start up there is smoke coming from the nearside housing and area under the front Carb. Once hot the smoke stops, it is water/coolant as I can smell that sweet smell of antifreeze. I am assuming that once hot and the thermostat is open, with pressure reduced, the leak stops. I have ordered a new gasket and three retaining screws/bolts and washers. In addition I have ordered some Blue Hylomar gasket sealant. Has anyone used this before. How much do you use and do you use it on both sides of the gasket.
Mike
#2 Re: Weeping Thermostat Housing
Posted: Mon Feb 10, 2020 5:03 pm
Hi Mike....thin smear both sides of gasket....can be applied to all mating surfaces if needs be....Steve
#3 Re: Weeping Thermostat Housing
Posted: Mon Feb 10, 2020 5:16 pm
by SESH
Thanks Steve, much appreciated.
Mike
#4 Re: Weeping Thermostat Housing
Posted: Mon Feb 17, 2020 9:08 am
by Neil Duke
Blue is available as an aerosol,hang the gaskets on thin wires,& spray a thin coat.
#5 Re: Weeping Thermostat Housing
Posted: Mon Feb 17, 2020 11:45 am
by SESH
Thanks for the tip Neil.
However, I now have a tube of the paste.
But good to know it's available as an aerosol.
Mike
