Series 3 V 12 Engine Parts
chris420sa
#1 Series 3 V 12 Engine Parts
Post by chris420sa » Thu Feb 27, 2020 3:16 pm
I'm about to have my Pre HE engine rebuilt.
I see that SNGB does not have a number of the engine parts in stock/no longer available.
SNGB does have pistons and liners (made by Mahle) but they are for 7.8:1 comp ratio, not 9:1.
Can you please advise preferred supplier of engine parts and particularly the higher CR pistons, rings, liners etc.
Many thanks
Best regards
Chris
Chris Davies
1972 Series 3 2+2
#2 Re: Series 3 V 12 Engine Parts
Post by mgcjag » Thu Feb 27, 2020 4:07 pm
Contact Rob Beere to see what they can offer http://www.rob-beere-racing.co.uk/engine12.html
sideways60
#3 Re: Series 3 V 12 Engine Parts
Post by sideways60 » Sat Feb 29, 2020 4:25 am
I Brought
The 9:1 Piston , Liner and Ring Kit
The New 20% Upgraded Oil Pump and PRV Kit
The Rear Oil Feed Pipe
The Rear Crank Oil Seal , Flywheel Upgrade Mod
From Rob Beere
showone
#4 Re: Series 3 V 12 Engine Parts
Post by showone » Sun Mar 08, 2020 12:48 am
I am in the U.S.A. and building the same engine. I got my liners from " Advanced Sleeve " in Cleveland
Ohio . What ever size you want , mine were 96 MM . Most piston companies will make any thing you
need. If you are interested I have a brand new set of extended length , H beam connecting rods for a
V12 , same ones I am using in my engine . Much stronger and 190 grams per rod lighter.
#5 Re: Series 3 V 12 Engine Parts
Post by PeterCrespin » Sun Mar 08, 2020 4:09 pm
Anybody Stateside doing a V12 rebuild who wants an 18,000 miles from new crank, let me know. Also oil pump. No idea on value but the shipping would probably be a bugger.
