#1 Indicator Fitment
Posted: Sat Apr 18, 2020 6:54 pm
Just removed indicators on my S3 to change the mounting rubbers as old ones a bit worn. When removed found that there was a large amount of what appears to be some form of rubber filler, which I had to carefully remove with a scrapper from the paint work. Not surprisingly the new ones do not fit properly with the expected gap. See images.
Does anyone know the reason for this, is it normal? I believe the previous owner had a new bonnet fitted, could it be that it is that at fault or the light clusters.
Here's hoping there is an easy solution.
I also not that one indicator has the lower half painted white, is there a reason for this and should both be the same.
Also how do you get the rubbers to remain in place when you refit the light clusters.
