#1 Cracked firewall
Posted: Mon May 11, 2020 8:36 am
by lowact
Where the centre bonnet latch mounts.
Anyone else experienced this?
Not sure why this is loaded, maybe I need to adjust my bonnet latches ...?
#2 Re: Cracked firewall
Posted: Mon May 11, 2020 11:20 am
by Mephistopheles
I experienced the same issue. I repaired it and reinforced this area with an angle plate...hopefully problem solved.
Best regatds
Holger
#3 Re: Cracked firewall
Posted: Mon May 11, 2020 12:01 pm
by AussieEtype
I do not have this on my car.
I wonder if this is a result of jacking the car at the front jacking points so the entire engine, front suspension is hanging off the firewall sags just a little putting load on the bonnet hook - trying to pull forward so pulling out that bit of metal.
Garry
#4 Re: Cracked firewall
Posted: Mon May 11, 2020 1:19 pm
by Bob.
How about this scenario?
Plan is to open the bonnet to the vertical position. Long enough chain is connected between the bonnet safety latch bracket and the little grill area of the bonnet. Bonnet is opened but gets away from the person opening it as the CofG goes forward of the pivots and bonnet snaps vertical, putting shock loading on scuttle area at latch mount. Bracket is bent absorbing some of the energy but tensile strength of sheet metal is exceeded and forward facing tear results.
