S3 underdash hardura and mill board RHD RH side
coalboy
#1 S3 underdash hardura and mill board RHD RH side
Post by coalboy » Mon Jun 01, 2020 8:07 am
Ok so enjoying time with the Jag during lock down doing some trim work putting right the previous owners work.
On the rh side does the under dash hardura bend over the front lip to go under where the steering column Bracket lower bolts fit and do they also glue onto the steering shaft cover? Photos appreciated. Also the mill boards which were missing do they go under the column too?
Help appreciated.
Nige
S3 OTS lavender blue
Doddsy
#2 Re: S3 underdash hardura and mill board RHD RH side
Post by Doddsy » Mon Jun 01, 2020 9:08 pm
Nigel, (Im another Series 3 Nigel owner) I will try and get a photo tomorrow but I definitely did not use any glue. There will come a time when you want to get these out to access various things from under the dash. I defiantly have mine installed above the lip (ie behind it). They do take a bit of messing with to fit and a bit of a curve helps. I have also now become quite adept at removing the shelf so you can access these.
Teddington UK. Series 3 OTS 1972. Owned since 1982.
coalboy
#3 Re: S3 underdash hardura and mill board RHD RH side
Post by coalboy » Tue Jun 02, 2020 8:19 pm
Thanks Nigel appreciate that
