#1 Steering Lock & Ignition Switch
Posted: Thu Jul 16, 2020 1:06 pm
Ignition switch has failed. I have purchased a replacement unit from SNG Barratt (part 37103). This new unit has a number stamped on the steering lock section (WGP622) and the wires from the ignition switch terminate in a 6 pin plug.
The number stamped on the old unit is WGP621 and the wires (White, Brown, White/yellow, White/red) terminate in a 4 pin plug (which fits into a 4 pin plug in the wiring harness).
Part # 37103 is the part listed for my Series 3 Roadster in the SNG Barratt catalogue - I have emailed them for clarification and/or what changes I need to make to the unit supplied to make it fit my vehicle. I ma awaiting a response - has anyone out there experienced a similar issue?
Cheers,
OOPS - numbers stamped on the steering lock are - New unit WGB622 - Old unit WGB621
Cheers,
