#1 V12 Rev Counter Needle Moving To Max When Ignition Turned On
Posted: Tue Jun 01, 2010 11:42 am
by airgun
Hi, I have a UK 1973 V12, when I turn the ignition on the rev counter needle goes right round the gauge. Any suggestions?
Thanks!
Posted: Fri Jun 04, 2010 10:21 am
by D COUPE
Hi Alan
Mine does exactly the same not ideal I know, BUT i made some enquieries on the subject and to have it tested and recond ?70 if
you need his number I have it
Thanks Dave C
73 SERIES 3 WHITE ROADSTER
Posted: Fri Jun 04, 2010 2:03 pm
by airgun
Thanks Dave
I think the problem may be wiring related. When I turn the key to the first position the rev counter moves approx. 1/3 of the way around the gauge, if I turn the heater fan on in instantly moves all the way round. I'm going to have a look at my workshop manual and check all the earth connections. I will report back if I get any success.
Edward.
Posted: Fri Jun 04, 2010 5:59 pm
by D COUPE
Thats good I have had a poke around and could not sort it so if you have any luck that would be good
Regards Dave C
Posted: Sat Jun 05, 2010 1:28 pm
by Heuer
The S3 tach is driven from the OPUS ignition system so make sure a previous owner has not connected it to the coil! It connects to the OPUS with a blue/white wire (I think) so check the plug is OK and making good contact although that usually causes a problem of the tach not working or being intermittent. The fault could also lie with the internal circuit of the OPUS or the tach itself. Unfortunately substitution with good known working parts is usually the only way to sort it.
This site might help:
http://www.reopus.co.uk/Original%20Wiring%20XJ12.html
#6 UK 1973 V12, tacho needle
Posted: Wed May 11, 2011 9:01 pm
by john.ball
mine intermittently does the same I have replaced the ballast and had the head checked I have as far as possible checked the live and neutral feed to the head with no improvement the next and only course of action left is the opus system itself
Posted: Thu May 12, 2011 12:09 am
by AussieEtype
I have had my series 3 for 27 years and it has always done it - turn on the ignition and the tach moves around to 7000rpm and then settles back to zero rpm - the tach runs as it should once the engine is running.
I have just put it down as a quirk nothing more.
Garry
