#1 Both speedometer & odometer not working
Posted: Mon Sep 28, 2020 2:47 am
by Soonteo
Wonder if anyone can advise why both my speedometer and odometer do not work on my 72 S3 E type.
Thank you
Tony
#2 Re: Both speedometer & odometer not working
Posted: Mon Sep 28, 2020 7:10 am
The most likely cause is that the speedo cable has failed. Another possibility is that the angle drive where the cable comes out of the gearbox ( RHS of box ) is broken
#3 Re: Both speedometer & odometer not working
Posted: Mon Sep 28, 2020 11:23 pm
by Soonteo
Thank you Chris. Will check them out.
#4 Re: Both speedometer & odometer not working
Posted: Wed Oct 07, 2020 3:59 am
by Soonteo
Found that the problem is the speedometer transducer mounted at the back of the speedometer gauge which is not spinning or jammed inside.
Appreciate any advice on where this can be repaired or purchased.
Thank you
Tony
#5 Re: Both speedometer & odometer not working
Posted: Wed Oct 07, 2020 7:21 am
by MarekH
You mean the right angled little gearbox mounted on to the back of the speedometer itself, I presume.
Check that the speedo turns freely without this fitted.
You can check the right angled little gearbox itself with a small screwdriver or square rod. It should turn 1:1 one way and possibly the other - (it may have a ratchet inside).
It may be that the end of the speedo cable is rounded off.
The part itself will be common to all Jaguar cars which have the steering wheel on the same side as you have. I might even have a few sitting in the loft somewhere if I can find them.
#6 Re: Both speedometer & odometer not working
Posted: Mon Oct 12, 2020 10:18 am
by Adamski
Speedograph Richfield have fixed all my gauges over the years including speedo's and new guts in the rev counter.
