#1 Clutch master cylinder spacer
Posted: Sun Nov 08, 2020 8:30 pm
by Curtis Bay
I am converting a series 3 V12 auto to manual and need to install a master cylinder on the existing pedal box.
I believe there is a spacer which is fitted between the cylinder and mounting but this is no longer available. Does anyone know how thick it is is that I can make one?
I know this subject has been raised before but rather inconclusively.
#2 Re: Clutch master cylinder spacer
Posted: Tue Nov 10, 2020 1:45 am
by lowact
My C31725 is 10.5 mm thick.
#3 Re: Clutch master cylinder spacer
Posted: Tue Nov 10, 2020 8:58 am
by Curtis Bay
Hello Colin
That's brilliant.
Many thanks.
#4 Re: Clutch master cylinder spacer
Posted: Tue Nov 10, 2020 7:25 pm
by madjack4
Burlins do a spacer offset for when SU carb conversion is fitted order one off them save u making one it just mounts master cylinder at slightly different angle
Regard Rob
#5 Re: Clutch master cylinder spacer
Posted: Sun Jul 18, 2021 9:56 pm
by Norton
Hi. Having some clutcproblems I saw this thread. Maybe late but came across a reproduction spacer plate from scparts:
https://www.scparts.co.uk/sc_en/spacer- ... 17755.html
My problem: Master cylinder pushrod dislocated. Tried to push clutch pedal it was stuck, pushing harder it suddenly floored with no resistance. Discowered pushrod is dangling from clutch pedal arm and bent ( probably from « pushing harder» ). Have not looked more into it right now, but anyone any ideas?
Rgds Harald
