#1 Sieve in oil suction pipe // thread oil sump
Posted: Wed Nov 18, 2020 9:53 pm
Today I wanted to do an oil change before the winter break. I noticed that the oil drain plug was only loose in the oil sump: I'm surprised that I didn't lose oil there! After draining the oil I had to find out that the thread of the oil sump is messed up: there is a helicoil like wire spiral in it, one turn of the spiral protrudes from the thread and is widened, moreover the spiral is too short, about half as long as the thread. I also found aluminium chips in the thread.
Is there a danger that the oil pump has sucked in possible aluminium chips or is there a sieve in the oil suction pipe?
If possible I do not want to remove the oil pan, but only repair the thread with a thread repair kit Helicoil 5/8-18 UNF.
Any expert advice on this?
Best regards
Holger
Best regards
Holger
