Does anyone have a spare or source for this (50 x 32mm) oblong-shaped grommet, used to protect the main loom as it passes through from the dash area to the engine compartment, near to the wiper motor / pedal housing?
I haven't managed to find a picture or part number, so the picture of the perished remains of mine is all I can offer by means of identification.
Not found anything even similar so far by extensive Googling, so I'm trying the forum before considering making something up.
S3 wiring loom main bulkhead grommet
#2 Re: S3 wiring loom main bulkhead grommet
Drewpy, I tried and failed to find the grommet when I rebuilt my Series 3. Mine was also in pretty poor state. There are I believe there are two solid plastic inserts which secure the flexible rubber in position. At least that is what I found. Very interested to see how this develops. I would like to see a picture fo what the full assembly should look like and of course where these can be purchased.
Teddington UK. Series 3 OTS 1972. Owned since 1982.
#3 Re: S3 wiring loom main bulkhead grommet
Hi Doddsy,
Yes, agree on the plastic insert; there is one remaining on mine, with a diagonal interlocking joint to lock it to the other (missing) insert by the look at it. Looks a very clever way to let the big connectors through, then provide a tight seal between the two areas of the car.
Drewpy
#4 Re: S3 wiring loom main bulkhead grommet
When replying to the original text I noticed that there was another post about this which included a photo of the grommet full assembled. When restoring my car I managed to reuse the original (also minus one of the plastic pieces) so it isn't great but had no alternative. if anyone manages to find a source I will be buying one for sure.
#5 Re: S3 wiring loom main bulkhead grommet
Hi Drewpy
The part number is C30670.
SNG Show its for the V12E £73.82 Inc Vat Special Order
David Manners show it for the XJ12 £60.00 Inc Vat special order
(As to the quality or availability that remains to be seen)
You could try Hutsons/M&C Wilkinson as they may know where to get it
Good Luck
Good Luck
V12 Series III 2+2 1973
#6 Re: S3 wiring loom main bulkhead grommet
Hi Drewpy
These people may be able to help - I have not looked for your grommet but they have the right company name!!
https://www.grommets.co.uk/
Mike
1969 S2 FHC
1969 S2 FHC
#7 Re: S3 wiring loom main bulkhead grommet
If enough people want them, then I might be tempted to do it at some future date. I had thought it was a no starter as nobody in their right mind would pay £45, but I might be wrong there.
#8 Re: S3 wiring loom main bulkhead grommet
Hi Marek - I'd certainly be interested to buy one from you (at a reasonable price).
Look forward to future developments (from your 3D printer!)
All the best
Chris
All the best
Chris
Chris Davies
1972 Series 3 2+2
1972 Series 3 2+2
