"Delilah and Samson"
73, S3 OTS, auto with drop-top and hard-top,35000 miles
Sadly the car has been resprayed, rather well, but not perfect. Beige Interior original 1973. I found evidence of rust and rust repair, but much less than expected.
So now the whole process of sorting out all the usual V12 issues starts all over again.
Already done:
- Thermostats removed, tested, reinstalled
- Fans come on but temperature at which they come on, not verified yet
- Carbs balanced (draw the same air at idle)
- Carbs synchronised (they all open at the same time)
- Needles removed, O-rings replaced, free movement of needles when adjusted verified, set to 1.5 turns out from full in (full rich). Final fuel tuning yet to be done.
- Remove OPUS ignition, install modern ignition system
- Set timing as per Philip's method (ignore "the book")
- Implement Philip's version of Lutz mod (4,6,12mm)
- Correct front ride height
- Engine, gearbox and diff sounds like it has done only 35k miles - it runs very quiet
- header tank leaks profusely, handed in for repair.
- 4200rpm @ 75mph !!!!!!
This is like driving my Coupe in 2nd all the time!!! (2.88 diff going in, in due course)
- Some slap dash aftermarket aircon system was installed in place of the usual heater box. Must all come out. AC pipes running right through the centre of the V !!! As if there is not enough going on there.
