V12 engine mounting angle
marks4108
#1 V12 engine mounting angle
Post by marks4108 » Mon Feb 15, 2021 7:30 pm
Hello all
Can anybody who has a v12 engine mount unbolted off the engine tell me what angle its bent at, £180 each sounds a bit steep to me for a fivers worth of steel so Im making my own.
Many Thanks
lowact
#2 Re: V12 engine mounting angle
Post by lowact » Wed Feb 17, 2021 3:53 am
Buy one make one the mirror image. Or realise its cheaper and buy 2 …
East-west the angle is the same as the angle on the frame mount, also the same as the engine vee, = 30 deg. North-south what is most critical is the location of the centre bolt hole for the rubber mount, I measure 122 mm back from the front of the block (not incl. front cover) and 70 mm below the top of the block (bottom of the head, i.e.:
marks4108
#3 Re: V12 engine mounting angle
Post by marks4108 » Wed Feb 17, 2021 8:16 pm
Hello Colin
Thank you for your posted pictures with dimensions they are perfect, I can make some from here, very kind of you to take the time.
Mark :salute:
