V12 automatic transmission problem
#1 V12 automatic transmission problem
Recently had the borg Warner transmission rebuilt parts where scares especially the bushings which were machined. Transmission works well however in the drive position as I come to a stop the rpm’s slowly bleed down and the car stalls. checked the knockdown micro switch on the tower and it is ok. Could the kick down solenoid be at fault I am baffled. Also the car idles at 1500Rpms and once put into drive the RPMs drop down to 950rpm but as I pull up to a light rpms bleed down till the car stalls
