Series 3 Throttle Linkage
chris420sa
#1 Series 3 Throttle Linkage
Post by chris420sa » Fri Mar 12, 2021 1:08 pm
Could you please advise where I can locate parts for the throttle linkage for the V12?
In particular I'm trying to find the "top hat" brass washer/bush Jag part number 12376 (page 25.45 of Parts Catalogue) but would also be helpful to replace some other parts of the "lower" linkage i.e. below the short operating lever C. 35841.
Also, does that "top hat" washer/bush need to be a flush fit with the rear side of the lever 12859 or should the washer/bush protrude further to the rear?
Look forward to your replies.
Best regards
Chris
Chris Davies
1972 Series 3 2+2
Bob.
#2 Re: Series 3 Throttle Linkage
Post by Bob. » Fri Mar 12, 2021 4:48 pm
Hi Chris,
Burlen's are probably the best bet for the 12376 bush and for advice. http://burlen.co.uk/
Bob
Bob
'71 S3
