#1 Air condition
Posted: Wed Mar 24, 2021 4:04 pm
1973 S3, air condition.
Hi.
My aircon fan switch is misbehaving and need fixing or replacement. But how are the switching sequence of this switch? Looking at the EL diagram its obivious that at position 1, you will have energized 1 terminal out of the swith to energize a/c thermostat switch, a/c radiator fan relay and a/c fan through a/c fan resistor.
Position 2 sends electricity at midpoint of resistor ( speeds up fan ).
I believe position 1 out of switch still needs to be energized otherwise thermostat switch and relay would also receive reduced current and / or overload the resistor.
Can anyone confirm this or put me right?
Same with pos 3, pos 1 also energized for same reason. In this case what about pos 2, also energized? Or does it matter?
Rgds Harald.
Hi.
Rgds Harald.
