Which Way Round
Neil Duke
#1 Which Way Round
Post by Neil Duke » Wed Apr 28, 2021 11:16 am
Which way round does the windscreen sealing rubber fit,on a roadster?,Or shall I just stand under a cold shower?
69 S2 2+2
07 Vanquish S
07 Vantage Roadster
65 Austin Healey 3000
66 Scimitar Coupe
He who dies with the most toys wins.
lowact
#2 Re: Which Way Round
Post by lowact » Wed Apr 28, 2021 11:53 am
Id'ing the sides in yr photo: 12, 2, 3, 6 and 9 o'clock.
3 o'clock is the top. 9 o'clock is the bottom (sits on the windscreen), 6 o'clock is facing backwards, 12 oclock is facing forwards. You are holding the LH end.
Neil Duke
#3 Re: Which Way Round
Post by Neil Duke » Wed Apr 28, 2021 1:13 pm
Thank you.I will try that.
69 S2 2+2
07 Vanquish S
07 Vantage Roadster
66 Scimitar Coupe
Doddsy
#4 Re: Which Way Round
Post by Doddsy » Thu Apr 29, 2021 7:37 am
Im interested to know how you plan to attach the seal into the channel. Which adhesive and which sides?
I have just replaced my seal and not convinced I have this correct.
Teddington UK. Series 3 OTS 1972. Owned since 1982.
Nialls Shortbear
Virgin Islands (USA)
#5 Re: Which Way Round
Post by Nialls Shortbear » Fri Apr 30, 2021 4:34 am
Stand under the shower, 1 minute for each of those venerable vehicles you own.
lowact
#6 Re: Which Way Round
Post by lowact » Fri Apr 30, 2021 12:32 pm
Yup, more toys u have, more cold showers you'll need. Its the showers that will get you, I think its one of the laws of natural deselection. For my part I didn't use any adhesive, I found after a couple of uses it was worked in there snugly. If I was going to use adhesive it would be the top edge only, and I would have the hood tightened down hard while the adhesive was setting.
