Roller bearing differential
Rui
Portugal
#1 Roller bearing differential
Post by Rui » Tue May 04, 2021 7:36 pm
Hello, (apologies for double posting)
Does anyone know where in UK can I source a replacement for the differential output shaft of a Series 3 ?
They are not anlylonger made, reference is SKF 41444 , which has a 29mm width with double ball rollers . Some suppliers have a replacement that it is 2mm thiner but need shimming , but I only found replacement kits in the US Therry jaguar parts, with include the 27 mm roller bearing and the inner and outer shims.
I started a discussion on this in
https://forums.jag-lovers.com/t/final-d ... /406010/15
But I found no solution in Europe, which is weird as this should be a relatively common problem.
Many thanks for any pointers :thankyouyellow:
Kind regards
Rui
#2 Re: Roller bearing differential
Post by mgcjag » Tue May 04, 2021 7:46 pm
Just replied to your duplicate post in the technical section.....Steve
