Help with brake m/cyl. pushrod clip?
Philip J iles
#1 Help with brake m/cyl. pushrod clip?
Post by Philip J iles » Tue May 11, 2021 3:54 pm
Hello all, really need some help locating a part which locates the brake master cylinder pushrod in the master cylinder piston end. We appear to have misplaced the original part somewhere. We have a pushrod with a machined recess about 5mm from the end of the shaft which goes into the m/cyl piston. However, we do not have the washer/ clip which holds the pushrod against the piston ( which is an open tube ). Can anyone help with a picture of said part or better still help us locate one to complete the build. Many thanks in anticipation ...
#2 Re: Help with brake m/cyl. pushrod clip?
Post by bitsobrits » Tue May 11, 2021 5:11 pm
The year and version of your E-type?
lowact
#3 Re: Help with brake m/cyl. pushrod clip?
Post by lowact » Wed May 12, 2021 2:21 am
There isn't a clip, the pushrod is inserted into the hollow end of the piston and is retained by the brake pedal.
Philip J iles
#4 Re: Help with brake m/cyl. pushrod clip?
Post by Philip J iles » Wed May 12, 2021 8:43 am
the car is a 73 OTS S3 V12. Really doesn't seem a very good solution/ design to have the pushrod just loose in the piston - surely this can't be how it was designed?
#5 Re: Help with brake m/cyl. pushrod clip?
Post by mgcjag » Wed May 12, 2021 8:49 am
It shows it as described in the Jaguar service manual......nothing holding it in...Steve
#6 Re: Help with brake m/cyl. pushrod clip?
Post by christopher storey » Wed May 12, 2021 9:32 am
As William Douglas used to say : "What you don't fit don't give no trouble"
There is absolutely no functional reason to keep the pushrod attached to the master cylinder : if it reaches the stage of being disconnected from the brake pedal then it is not going to work anyway
lowact
#7 Re: Help with brake m/cyl. pushrod clip?
Post by lowact » Wed May 12, 2021 11:27 am
The piston moves in a straight line. The pushrod doesn't, it is pivoted. The design accommodates this and lots of adjustment, after which It won't be loose.
