#1 Ideas to reduce heat in car on Series 3 V12
Posted: Fri May 28, 2021 10:03 am
by GraemeT
Dear Forum members,
I'm looking for ideas to reduce the heat in the car when running the V12. It gets uncomfortable. I dont have an AC, will put additional floor insulation and consider a vent to the bulk head. Any other advice appreciated.
thanks
Graeme
#2 Re: Ideas to reduce heat in car on Series 3 V12
Posted: Fri May 28, 2021 11:44 am
by Gfhug
Graeme, welcome to the forum, the best place for all things E Type.
You'll see some ideas below in suggested topics but a search of the forum will show you lots of ideas people have used, eg dynamat. Search works very well by simply putting in one word in the box (eg insulation or dynamat), then when the results come up you can refine then with the "search these results box".
Tell us more about your car, how long you have had it, photos are always welcome.
Good luck
#3 Re: Ideas to reduce heat in car on Series 3 V12
Posted: Fri May 28, 2021 2:29 pm
by MarekH
If you have a later v12, then the fresh air ventilation system fed from the picture frame can be beefed up with a couple of simple air scoops to redirect air from the air dams into the ducting.
See
https://forums.jag-lovers.com/t/what-di ... 58680/7088 for details
#4 Re: Ideas to reduce heat in car on Series 3 V12
Posted: Sat May 29, 2021 7:56 am
by GraemeT
thanks MarekH
#5 Re: Ideas to reduce heat in car on Series 3 V12
Posted: Sat May 29, 2021 8:00 am
by GraemeT
Gfhug wrote: ↑Fri May 28, 2021 11:44 am
Good luck
THanks Geoff, had her on the road now for a month after a nut and bolt rebuild and really enjoying her. SHe is a 71' in willow green with a cinammon interior. I've done upgrades on the engine, add a stainless steel exhaust system and polybushed her all around, drives and handles great.... looking forward to many more miles.
Appreciate the guidance on the heat wrap.
Graeme
#6 Re: Ideas to reduce heat in car on Series 3 V12
Posted: Sat May 29, 2021 8:23 am
by AussieEtype
Do you still have the original heat shields - one up on the engine side of the firewall around the transmission tunnel and the second above the exhaust pipes/mufflers? Without these a lot of heat will enter the cabin.
I would consider the later footwell ventilation that was fitted to later series 3s.
#7 Re: Ideas to reduce heat in car on Series 3 V12
Posted: Thu Jun 10, 2021 9:52 am
by GraemeT
AussieEtype wrote: ↑Sat May 29, 2021 8:23 am
Many thanks, I'm in the process of fitting a 5-speed manual box now, have put heat protection now in the tunnel, wrapped the exhausts, have put dynamat in the floor wells and will cover the bulk head and the gearbox / internal area and have installed the missing rams and piping to take the external airflow from the bonnet to the foot we
- Bulk head flanges for air.jpg (192.24 KiB) Viewed 8051 times
ll! Hopefully will have her on the road this weekend and head to the Shelshley Walsh e60 meet in Worcestshire on Sunday...
thanks to all and the forum for the guidance, great advice!!
Graeme
#8 Re: Ideas to reduce heat in car on Series 3 V12
Posted: Fri Jun 11, 2021 4:48 am
by AussieEtype
So I take it that you do not have the original heatshields in place - I would put them in and also do the insulating you have indicated above.
#9 Re: Ideas to reduce heat in car on Series 3 V12
Posted: Fri Jun 11, 2021 11:47 am
by myJagV12
Hi Greame,
What is wrong with your AC ?
Which Gearbox are you thinking of ?
Good luck for having everything done by Sunday !
BR, Tom
#10 Re: Ideas to reduce heat in car on Series 3 V12
Posted: Tue Aug 03, 2021 8:56 pm
by Adamski
Yes lots of heat with all shields in place. It comes in from the bulkhead. I am lucky enough to have a Webasto from new. Does the trick.
#11 Re: Ideas to reduce heat in car on Series 3 V12
Posted: Tue Aug 03, 2021 9:48 pm
by madjack4
Hi if you are running the distributor with the vac retard that makes the engine run much hotter on the exhausts.When i fitted the vac advance it made a big difference to the temp in the cabin as the exhausts run much cooler
#12 Re: Ideas to reduce heat in car on Series 3 V12
Posted: Wed Aug 04, 2021 8:10 am
by Adamski
Yes on retard diaphragm(replaced many times) But it is only active at tickover I seem to remember,
Once you're rolling the advance bob weights kick in, certainly on my strobe markings that I've spent ages gaping into!.
