#1 Installing sugar scoops on bonnet
Posted: Wed Jul 07, 2021 6:55 pm
by Bchichi
I had My 1981 etype series 3 painted anc am in the process of putting back the trim windows and chrome parts but was hoping some one could help me in reinstalling the sugar scoops. I purchased the proper poop rivets with the washes and trim support rings and could use a good photo of two of the spacing of the rivets my scoops hag a lot of previous holes drill in them from a previous repair and it’s a bit confusing now and I don’t want to drill the wrong holes in the fresh painted bonnet . Any help would be appreciated ! Thank you
#2 Re: Installing sugar scoops on bonnet
Posted: Thu Jul 08, 2021 10:24 am
by vee12eman
It would be great if you could create a signature block with your name and E-type model in it, helpful too.
Here are some photos of my scoops from installation on my S3. They are held in place with grip pins in the rivet holes.
#3 Re: Installing sugar scoops on bonnet
Posted: Thu Jul 08, 2021 2:50 pm
by Bchichi
Thank you for your great photos of the sugar scoops , were did you get the proper pop rivets and do you know the parts # for them? . I already purchase two different sized ones from Moss and British parts Northwest and neither are the correct ones for the sugar scoops and the trim.
I did try to post my personal info and couldn't figure were I do that on the web site. Can you tell where I do that too?
Thank you again for any help.
Brian Chichi
949 922 2396
Southern California
etype 1971 2+2 owner
#4 Re: Installing sugar scoops on bonnet
Posted: Thu Jul 08, 2021 8:33 pm
by vee12eman
Hi Brian,
Nice to meet you and the car looks great, welcome. I bought rivets about 15 years ago, but pretty sure it was from SNG Barratt I. Almost everything else was from there. I think I may have used tiny washers under the Clips/buttons/washers to allow the trim to clip on more easily. It was a long time ago.
Part numbers from SNG:
Rivets:
BD31095/1
BD31095/2
Clips/buttons/washer (depending what you call it):
AW105/T
To add a signature, tap your user name, (top right), then tap User control panel, then Profile and there should be an edit signature option.
Hopefully that helps
#5 Re: Installing sugar scoops on bonnet
Posted: Sat Jul 10, 2021 1:58 pm
by Bchichi
Thank you David I will try t get them from them using those # s. I did get one scoop on with the rivet clips and washers I already had purchased, but the trim doesn't want to slip on to the new rivet head. I think the newer seal is much thicker than the original one I took off. Any ideas on that problem?
#6 Re: Installing sugar scoops on bonnet
Posted: Sat Jul 10, 2021 8:49 pm
by vee12eman
Hi Brian,
I can’t really add much more, it was so long back. I remember it being difficult and I bent one of the trim pieces trying to use too much force. Fortunately it was only at the back that the bend occurred, the rivet pushed the flanges inward and I was able to very carefully bend them out again, using a screwdriver, they are brass and quite soft. After that I was more gentle and put the rubber mallet I had been using away!
Simon.
#7 Re: Installing sugar scoops on bonnet
Posted: Sun Jul 11, 2021 2:41 pm
by Bchichi
Thank you for your help. I got the sugar scoop installed and the rubber seal glue down yesterday . Today I’ll tackle the trim pieces. I send a photo of how they came out. Have a great Sunday !
