#1 1971 Jaguar E-Type Series 3 - Desperately require LH Exhaust Manifolds
Posted: Thu Sep 09, 2021 4:39 pm
by tonyS
Hi Everyone,
I was really hoping if someone could help me.
I've been searching for a set of replacement LH Exhaust Manifolds for a Jaguar Series 3 with no luck what so ever.
I beleive the part numbers are c39109 & c39110.
If some one has a set of used/reconditioned or new ones available please please and pretty please can I buy them of you?
My car has been set at a garage for the last 2 weeks and they cannot source any :(
Thanks so much in advance.
Tony
1971 Jaguar E-Type Series 3, V12 2+2 Coupe
#2 Re: 1971 Jaguar E-Type Series 3 - Desperately require LH Exhaust Manifolds
Posted: Thu Sep 09, 2021 4:48 pm
Post in the wanted section....or new here
https://www.martinrobey.com/part/121778 Steve
#3 Re: 1971 Jaguar E-Type Series 3 - Desperately require LH Exhaust Manifolds
Posted: Thu Sep 09, 2021 4:59 pm
by tonyS
Thanks Steve,
I will re-post
Thanks for the link, very much appreciated - will try them tomorrow
Kindest Regards
Tony
#4 Re: 1971 Jaguar E-Type Series 3 - Desperately require LH Exhaust Manifolds
Posted: Thu Sep 09, 2021 9:30 pm
Moss in the US has c39110 in stock but they're not cheap.
https://mossmotors.com/exhaust-manifold ... right-rear
Jag-Daim in Australia has both new on EBay. Again not cheap.
https://www.ebay.com.au/itm/192653089812
#5 Re: 1971 Jaguar E-Type Series 3 - Desperately require LH Exhaust Manifolds
Posted: Thu Sep 09, 2021 10:15 pm
by angelw
Hello Andrew,
Unless the "After Market" units have been improved, you have to purchase a set for one side (these are the same for each side, but in reverse location), even when one is required, as the single end where the down pipes attach stick out closer to the engine frame and doesn't line up with an original header. That may not apply to S3 Headers from all the suppliers, but it has been the case from two suppliers I've tried.
Tony is seeking a complete set for one side, so he should be OK, but they don't lay as close to the engine as one would like.
#6 Re: 1971 Jaguar E-Type Series 3 - Desperately require LH Exhaust Manifolds
Posted: Thu Sep 09, 2021 10:21 pm
by angelw
Hello Tony,
It may broaden your search if you also look for a set of RH Exhaust Headers, as they are the same, only in revers location, when applied to the opposite side of the engine. Those who may have a set of headers for sale may not know that and are advertising them as per the side of the engine they were removed from.
#7 Re: 1971 Jaguar E-Type Series 3 - Desperately require LH Exhaust Manifolds
Posted: Fri Sep 10, 2021 9:26 am
by tonyS
Thanks everyone for your advice.
Seems to be a shortgae everywhere in respect to new parts due to tooling and machining issues backlog of 4 to 6 weeks
Will try the used parts market, may need to source from US it seems
Kindest Regards
Tony
#8 Re: 1971 Jaguar E-Type Series 3 - Desperately require LH Exhaust Manifolds
Posted: Fri Sep 10, 2021 3:36 pm
by MarekH
Dear Tony,
I have a couple of sets available
Contact me via the message service
#9 Re: 1971 Jaguar E-Type Series 3 - Desperately require LH Exhaust Manifolds
Posted: Fri Sep 10, 2021 5:39 pm
by tonyS
Thanks Marek,
I have messaged you.
Kindest Regards,
Tony
#10 Re: 1971 Jaguar E-Type Series 3 - Desperately require LH Exhaust Manifolds
Posted: Sat Sep 11, 2021 2:34 pm
by tonyS
A very happy weekend to all,
Not had much luck sourcing parts C39109/C391010 here in the uk as yet, however there is a supplier in the US that does have a set of used exhaust manifolds available for a Jaguar XKE Series 3 V12 but have the part numbers C34120/C34125.
They look very similar, does anyone know whether these will fit - pictures below.
Thanks Tony
