Which Ignition
kevh
#1 Which Ignition
Post by kevh » Sun May 15, 2022 6:48 am
My car has Luminition ignition which is working without any issues but I think it was fitted when Adam was a lad so I will be looking to replace it before it tells me I have to :wink:
Question for all you guys who have already done this is which would you fit now?
Kev
1969 S2 Coupe
1973 S3 OTS
2003 XKR Convertible
1935 Rover 12
#2 Re: Which Ignition
Post by abowie » Sun May 15, 2022 10:02 am
If it works, I would leave it well alone.
My XJS has an older Crane XR700 system, and it is unreliable. I plan to replace it all with a Pertronix Digital HP module and Pertronix distributor insert.
If it worked however, I would leave it well alone.
881824, 1E21538. 889457. 1961 3.4l Mk2. 1975 XJS.
MontanaDiver
#3 Re: Which Ignition
Post by MontanaDiver » Sat Sep 03, 2022 4:50 am
I fitted the SNG replacement unit. The only change I would make is to go to a vacuum advance, mine is retard USA spec, and have carb drilled for that vacuum source. Otherwise their system has been great. I thought I was having issues with the module/igniter but I was having a vapor lock issue in hot weather.
Dennis
Dennis
74 E-type OTS 4 speed
Great Falls, Montana
jagwit
#4 Re: Which Ignition
Post by jagwit » Fri Oct 21, 2022 8:50 am
In my opinion the pertronix 9lu-1122a (Please note the "a" at the end of the part no is MOST important) is a very cost effective and elegant solution for the V12 now. Have not used it myself though.
I would recommend this upgrade be implemented with the vacuum advance module JLM519 on the dissy connected directly to manifold vacuum. Both my S3's run beautifully like this.
Best Regards
Philip
Jag: 72 S3 XKE, 73 S3 XKE OTS, 80 XJS (Megasquirt + 5sp manual O/D)
