#1 Thermostatic fan switch
Posted: Fri Jun 17, 2022 10:03 am
by thermojac
:I am replacing my faulty 2 pin thermostat switch with an 'Otter" type switch but when I test it in boiling water the resistance goes from 17 meg to open circuit 🤔. I was expecting it to short out between spade connector and body of until. Am I being stupid or missing something here?
#2 Re: Thermostatic fan switch
Posted: Fri Jun 17, 2022 9:01 pm
by MarekH
No and no.
You'll have to buy one that works.
#3 Re: Thermostatic fan switch
Posted: Sat Jun 18, 2022 1:26 pm
by Allrand
The unit sounds OK, it'll only short out to the body of the unit when it reaches switch on temperatue.
#4 Re: Thermostatic fan switch
Posted: Sat Jun 18, 2022 2:05 pm
by thermojac
Thanks Marek. I thought I would safe buying from SNG 🥴
#5 Re: Thermostatic fan switch
Posted: Sat Jun 18, 2022 4:57 pm
by Craig Balzer
I can recommend Cool Cat's
https://www.coolcatcorp.com/Merchant5/m ... e=Cooling3
SNG Barratt's is cheaper but is only the otter switch.
https://www.sngbarratt.com/English(US)/ ... a0b4f9d04e
What condition is your T-pipe in?
#6 Re: Thermostatic fan switch
Posted: Sat Jun 18, 2022 6:56 pm
by MarekH
A one pin switch would indeed have to connect up the switch body to complete the circuit. The s3 loom expects a two pin switch so it sounds like you'd have to make an adapter if you were to use that switch.
The switch on and off temperatures are linked to the thermostat rating.
The s3 used 82'c thermostats.
Using the wrong spec Otter switch would mean the fan comes on and goes off "not quite in sync" with the expected water temperatures given that the thermostat sets the lower operating bound of that temperature range.
Expect the s3 radiator to drop the water temperature ~15'c
#7 Re: Thermostatic fan switch
Posted: Sat Jun 18, 2022 9:36 pm
by Series1 Stu
thermojac wrote: ↑
Do you really mean open circuit, or do you mean short circuit? The latter would be correct.
#8 Re: Thermostatic fan switch
Posted: Sun Jun 19, 2022 3:07 pm
by thermojac
T pipe is in good condition Craig.
Marek, I ordered pt no C37392 > C45086 from SNG which is the part listed for the V12 so I would expect the temp rating to be correct. You are right about the loom and I was planning to connect the spade to W2 and the body to C3 terminals on the relay.
I did mean open circuit Stu and I was expecting a short circuit.
I will get onto SNG tomorrow for a replacement.
#9 Re: Thermostatic fan switch
Posted: Wed Jun 22, 2022 12:19 pm
by baganz.sven@web.de
I also installed the coolcat version.
Works without problem.
sven
#10 Re: Thermostatic fan switch
Posted: Mon Jul 11, 2022 7:53 pm
by thermojac
Sorry for taking so long yo conclude the string. New thermostat acquired and system working well :smile:
#11 Re: Thermostatic fan switch
Posted: Mon Jul 11, 2022 9:58 pm
by rswaffie
Good news. It got a good test on Sunday!
#12 Re: Thermostatic fan switch
Posted: Tue Jul 12, 2022 4:18 pm
by thermojac
Much to my significant relief :bigrin:
