Vacuum feed?
NATO
#1 Vacuum feed?
Post by NATO » Fri Sep 23, 2022 10:45 am
I am doing some repairs to the fuel system due to ethanol degrading various hoses and o-rings, and noticed what looks like a vacuum feed that’s not connected to anything. Any ideas what or where it should be connected to?
Neil
1974 Series 3 E-Type
Jaguar I Pace
2013 F Type V8
MarekH
#2 Re: Vacuum feed?
Post by MarekH » Fri Sep 23, 2022 11:09 am
The bottom of the left rear carburettor was originally connected to the distributor vacuum retard capsule to retard the ignition at idle.
NATO
#3 Re: Vacuum feed?
Post by NATO » Fri Sep 23, 2022 1:54 pm
Looks like it has been changed sometime over its life as no vacuum on the distributor now.
Thanks for your help.
Jaguar I Pace
2013 F Type V8
lowact
#4 Re: Vacuum feed?
Post by lowact » Sun Sep 25, 2022 11:57 pm
Block it off, remove the rubber elbow, replace it with a rubber cap, to improve idle and efficiency.
