I am doing some repairs to the fuel system due to ethanol degrading various hoses and o-rings, and noticed what looks like a vacuum feed that’s not connected to anything. Any ideas what or where it should be connected to?
Neil
Vacuum feed?
#1 Vacuum feed?
- Attachments
- 8339516B-DD88-41F8-A926-01AE21F129AF.jpeg (87.46 KiB) Viewed 4155 times
1974 Series 3 E-Type
Jaguar I Pace
2013 F Type V8
Jaguar I Pace
2013 F Type V8
#2 Re: Vacuum feed?
The bottom of the left rear carburettor was originally connected to the distributor vacuum retard capsule to retard the ignition at idle.
#3 Re: Vacuum feed?
Looks like it has been changed sometime over its life as no vacuum on the distributor now.
Thanks for your help.
- Attachments
- E7AFF1FB-E71D-4827-A067-2386837FE555.jpeg (98.42 KiB) Viewed 4135 times
Jaguar I Pace
2013 F Type V8
Jaguar I Pace
2013 F Type V8
#4 Re: Vacuum feed?
Block it off, remove the rubber elbow, replace it with a rubber cap, to improve idle and efficiency.
