Does anyone have or can point me in the direction of photos showing the routing of the HP and LP pipes between the PS pump and the rack? RHD car.
Is it just me that only takes pics. that are never needed while not snapping what becomes essential?
Power Steering
#2 Re: Power Steering
I am sure someone will have some good images but here are a couple I have come across in the past. Beware the misleading reflections on the glossy black upright.
Bob
'71 S3
'71 S3
#3 Re: Power Steering
If you're allowed to improve it, I did it like this:
Even better if I'd had a RHD pinion, all the pipes could then all be above (the pinion). Uses the std LHD hoses.
#4 Re: Power Steering
Hi Pete,
do these pics help you?
I took them in '17 during the dismantling process..
Or maybe you've solved the problem now..
I've just seen your post..
My S3 is manual, RHD.
Colin
Colin
Colin
my project - XKE Series 3 2+2 manual coupe
