#1 How does the JD40 cam sprocket tool work?
Posted: Mon Jul 03, 2023 3:05 pm
Hi all. Looking for some advice on my V12 engine.
I have it out at the moment while the gearbox is fixed and although the engine runs well there has always been a bit of a tap which sounds like it comes from the top end. While it is out I have checked the valve clearances and if anything they are a bit tight. Some are down to 10 thou. I would like to change the cam chain and set the valve clearances. Reading through the ROM it talks about fitting the JD40 tool to retain the cam sprocket. But just how does this tool fit?
There is a bracket that comes up outside the sprocket with a "U" shaped slot in it and I can see that the took fits into the groove on the shaft coming out of the sprocket centre. Does the tool engage with this bracket somehow? If not then just what does the JD40 tool do?
Any advice much appreciated.
