Black spark plugs
#1 Black spark plugs
Felt like my baby was not firing on all cylinders. When I removed them ,all B 1-6 plugs. Side on which carbs are mounted were coke black. Any suggestions
1972 OTS
Opalescent silver blue
Purchased Oct 2020
Purchased Oct 2020
#2 Re: Black spark plugs
Was bank B running rich for any reason? check the state of bank A plugs.
Jack the lad
#3 Re: Black spark plugs
Worth checking the choke cables are not sticking in the "on" position. Also worth checking is the height of the main jet tubes in the centre of the carbs.
Jack the lad
#4 Re: Black spark plugs
I've just re-read your question and now ask: Are you sure you have a V12? as both sides of the car should have carbs mounted not just the B side as stated in your opening statement.
