The engine had 2 bend valves when I got it, so that needed fixing. The heads did not look great so I had them resurfaced as well, new valves, replaced the timing chain and tensioner, new SNGB ignition. Well I rebuild most, but let the pistons be because those looked good.
Started the engine first time and noticed that the A side is running much hotter than B. Exhaust gases also much hotter from the A side pipe. A1 and A6 spark plugs had what looks like dry black carbon deposit on them (easy to clean) after running for maybe 5 minutes. All other plugs looked good.
Checked compression on a couple of cylinders, about 150 psi, also on A1 and A6. Ran the engine with the spark plug out and A1 and A6 has spark. Exchanged A1 and A6 ignition leads with some other, still runs hot on A1 and A6. The A side carbs draw clearly less air than the B side.
Engine seems to run fine at 1000 rpm, but below that it stutters. Timing is also close, but a bit hard to check precise because of the rough running / stalling near 600rpm.
So
1) compression good,
2) A2 - A4 sparks plugs look ok, so A side carbs ok, so we have fuel on A1 and A6 I assume.
3) timing close to ok.
Any help with trouble shooting is much appreciated
