#1 Misfire hunt!!!
Posted: Sun Jan 28, 2024 12:57 pm
Hi all, over the past year or so I’ve been chasing a misfire on my 1971 series 3, new leads, plugs and SNG Barrett ignition system fitted, I’ve just noticed that on the near side pair of carbs, if I spray some carb cleaner around the gasket area when idling it pick up revs …. On the off side carbs, no difference at all, I suspect I may have a leak on both intakes, would this cause a misfire, tbh the car starts easily, but is just a bit lumpy??
