Electrical Gauges Not Registering
Redman
#1 Electrical Gauges Not Registering
Post by Redman » Mon Aug 26, 2024 4:11 pm
As of a week ago, when firing up the car all the electrical guages fail to move / register. After about 15 minutes on the road they all spring into life at the same time. This includes the rev counter. Ground issue? If so, anyone able to say where is it likely to be (that affects them all like this). But is rev counter also on a common ground? A steer in the right direction could help me avoid hours of fault chasing in and around the fuse / electrical panel and in the engine bay! Regards. Gordon
Gordon James
S3 1971 - Original (JHT) LHD/Auto/Air Con. Re-imported from US via UK in 1994, rebuilt Antwerp. Dk Blue (orig Sable)/Biscuit (orig Beige)
Porsche 911SC 1983
VW T2A Bus 1971
VW Beetle Cabrio 1967 (but bit of a mixture!)
#2 Re: Electrical Gauges Not Registering
Post by MarekH » Mon Aug 26, 2024 5:06 pm
Look at the wiring diagram. They are all common to fuse 7. See if other items on that fuse are also affected before quarter of an hour has passed.
#3 Re: Electrical Gauges Not Registering
Post by DWW » Tue Aug 27, 2024 3:32 pm
I had a similar issue, the fuse itself was faulty.
Redman
#4 Re: Electrical Gauges Not Registering
Post by Redman » Thu Sep 05, 2024 10:05 am
Hmmm. Both fuses 6 and 7 look brand new and seem perfect. Certainly passing current. There is one wire termination that looks a bit dodgy so will re-do and report. In the meantime, the symptoms continue - guages only spring to life after 15-20 mins.
Gordon James
Porsche 911SC 1983
VW T2A Bus 1971
Allrand
#5 Re: Electrical Gauges Not Registering
Post by Allrand » Sat Sep 07, 2024 8:31 am
Check them for continuity, and also the fuse blocks between the spring clips & the spade terminals.
Randall Botha
Redman
#6 Re: Electrical Gauges Not Registering
Post by Redman » Sat Oct 26, 2024 12:46 pm
Just to close this off - and many thanks again for the input from fellow Jag owners: it was indeed a wiring issue. I re-terminated a couple of highly suspect wires (W + W/B) running from the hot side of Fuse 6 to the hot side of Fuse 7 and all is now well.
Gordon James
Porsche 911SC 1983
VW T2A Bus 1971
