#1 Electrical Gauges Not Registering
Posted: Mon Aug 26, 2024 4:11 pm
by Redman
As of a week ago, when firing up the car all the electrical guages fail to move / register. After about 15 minutes on the road they all spring into life at the same time. This includes the rev counter. Ground issue? If so, anyone able to say where is it likely to be (that affects them all like this). But is rev counter also on a common ground? A steer in the right direction could help me avoid hours of fault chasing in and around the fuse / electrical panel and in the engine bay! Regards. Gordon
#2 Re: Electrical Gauges Not Registering
Posted: Mon Aug 26, 2024 5:06 pm
by MarekH
Look at the wiring diagram. They are all common to fuse 7. See if other items on that fuse are also affected before quarter of an hour has passed.
#3 Re: Electrical Gauges Not Registering
Posted: Tue Aug 27, 2024 3:32 pm
by DWW
I had a similar issue, the fuse itself was faulty.
#4 Re: Electrical Gauges Not Registering
Posted: Thu Sep 05, 2024 10:05 am
by Redman
Hmmm. Both fuses 6 and 7 look brand new and seem perfect. Certainly passing current. There is one wire termination that looks a bit dodgy so will re-do and report. In the meantime, the symptoms continue - guages only spring to life after 15-20 mins.
#5 Re: Electrical Gauges Not Registering
Posted: Sat Sep 07, 2024 8:31 am
by Allrand
Check them for continuity, and also the fuse blocks between the spring clips & the spade terminals.
#6 Re: Electrical Gauges Not Registering
Posted: Sat Oct 26, 2024 12:46 pm
by Redman
Just to close this off - and many thanks again for the input from fellow Jag owners: it was indeed a wiring issue. I re-terminated a couple of highly suspect wires (W + W/B) running from the hot side of Fuse 6 to the hot side of Fuse 7 and all is now well.
