#1 Compression test on 7.8:1 engine
Posted: Sun Sep 29, 2024 3:54 pm
Ive just performed (and repeated) a pressure test on my US spec car and got these results.
Bank A 95 95 87 95 93 100
Bank B 110 112 115 115 108 110
(squirting oil in cyl A3 increased it to 95psi)
Although fairly consistent between each bank Bank A is consistently lower that Bank B
Ive rebuilt the carbs and set the tappets but not yet tuned it. Could the lack of tuning cause this or what else could cause one bank to be consistently higher?
Also my gauge is a cheapo so psi results may be low but what psi should be expected for a 7.8:1 engine?
Is the ballpark atmospheric pressure x comp. ratio a good expectation ie
7.8 x 14.5psi = 113psi.
I would really like to remove head except Ive read too many horror stories re corroded studs!
thanks
David Offord
thanks
David Offord
