Kick down switch
Ikebaddog
#1 Kick down switch
Post by Ikebaddog » Sun Apr 27, 2025 2:35 pm
Ok fellas, Sunday evening question for the collective…. Quick summary of work I’ve done on my ‘71 V12
Removed and replaced passenger side carbs using all new gaskets, se timing as per discussion with MarekH, took her out for a proper blast today, easy to start, plenty of torque, however, the gearbox will only change up at kick down speeds…obviously with the work I’ve carried out, a lot of things have been disturbed…. Where would be your first point of investigation??
S3 2+2 1971
#2 Re: Kick down switch
Post by MarekH » Sun Apr 27, 2025 2:48 pm
I'd check the vacuum connection to the gearbox. It's on the left side of the car irrc.
Ikebaddog
#3 Re: Kick down switch
Post by Ikebaddog » Sun Apr 27, 2025 2:58 pm
Does that connect to the left hand intake manifold?
S3 2+2 1971
Ikebaddog
#4 Re: Kick down switch
Post by Ikebaddog » Sat May 17, 2025 2:15 pm
Hi MarekH, I’ve been under the car with the front lifted, but couldn’t find the location of the vacuum pipe, I’ve now got the rear of the car lifted, do you know where I should be looking for the connection, do I need to remove anything first, any help would be greatly appreciated
S3 2+2 1971
#5 Re: Kick down switch
Post by MarekH » Sat May 17, 2025 6:31 pm
Since you have access, just start at the rear of the left black manifold and follow it all of the way to the gearbox. The hard line ends just aft of the green plate on the autobox and goes through a 180' turn to enter the gearbox from behind.
Ikebaddog
#6 Re: Kick down switch
Post by Ikebaddog » Sat May 17, 2025 6:49 pm
Thanks MarekH, you are the font of information...Top Fella
S3 2+2 1971
Ikebaddog
#7 Re: Kick down switch
Post by Ikebaddog » Sun May 18, 2025 12:45 pm
MarekH…. You sir are a star, found the disconnected hose, reconnected to hard pipe, will test tomorrow, but I know you have found the problem, cheers fella👍👍
S3 2+2 1971
Ikebaddog
#8 Re: Kick down switch
Post by Ikebaddog » Mon May 19, 2025 11:55 am
Tested and all is good!!!
S3 2+2 1971
