Ok fellas, Sunday evening question for the collective…. Quick summary of work I’ve done on my ‘71 V12
Removed and replaced passenger side carbs using all new gaskets, se timing as per discussion with MarekH, took her out for a proper blast today, easy to start, plenty of torque, however, the gearbox will only change up at kick down speeds…obviously with the work I’ve carried out, a lot of things have been disturbed…. Where would be your first point of investigation??
Kick down switch
#2 Re: Kick down switch
I'd check the vacuum connection to the gearbox. It's on the left side of the car irrc.
#3 Re: Kick down switch
Does that connect to the left hand intake manifold?
S3 2+2 1971
S3 2+2 1971
#4 Re: Kick down switch
Hi MarekH, I’ve been under the car with the front lifted, but couldn’t find the location of the vacuum pipe, I’ve now got the rear of the car lifted, do you know where I should be looking for the connection, do I need to remove anything first, any help would be greatly appreciated
S3 2+2 1971
S3 2+2 1971
#5 Re: Kick down switch
Since you have access, just start at the rear of the left black manifold and follow it all of the way to the gearbox. The hard line ends just aft of the green plate on the autobox and goes through a 180' turn to enter the gearbox from behind.
#6 Re: Kick down switch
Thanks MarekH, you are the font of information...Top Fella
S3 2+2 1971
S3 2+2 1971
#7 Re: Kick down switch
MarekH…. You sir are a star, found the disconnected hose, reconnected to hard pipe, will test tomorrow, but I know you have found the problem, cheers fella
S3 2+2 1971
S3 2+2 1971
#8 Re: Kick down switch
Tested and all is good!!!
S3 2+2 1971
S3 2+2 1971
