#1 S3 fuel pump issue
Posted: Wed Oct 01, 2025 9:38 am
Hi All,
I’m replacing an old aftermarket Facet fuel pump on a 1972 V12 and installed the SU twin electronic pump.
It starts clicking & pumping okay, but the engine will only idle, cannot rev the engine then intermittent clicks, then cuts out and engine stops.
Any ideal what the problem is?
Or should I go for a replacement facet pump with a fuel filter/regulator?
Cheers,
Cheers,
