#1 S3 Clock Wiring
Posted: Wed Nov 05, 2025 2:00 pm
by Redman
Have had the clock refurbished and I have reinstalled. Wiring diagram says power comes from purple wire from Fuse 3 via interior light switch, however although I do have a "spare" purple wire from that switch it does not provide power. I found (!) an additional purple wire coming from the lights switch and that works fine. But where should the other wire from the interior lights switch go?
#2 Re: S3 Clock Wiring
Posted: Wed Nov 05, 2025 5:32 pm
by Craig Balzer
Maybe these'll help
https://www.youtube.com/shorts/RS0oLHfILs8
https://www.youtube.com/shorts/O-7ISSjSLhQ
I have Youtube shorts/videos (like these) for all the S3 switches as well as the gauges on my Youtube Channel
#3 Re: S3 Clock Wiring
Posted: Thu Nov 06, 2025 11:06 pm
by Redman
Thanks, Craig - have had a look at your channel. I think some extra time needed with a multimeter in and around the interior light switch and fuse 3! You have encouraged me to get into it.
#4 Re: S3 Clock Wiring
Posted: Fri Jan 23, 2026 1:47 am
by Redman
Sorted. Problem was indeed fuse / fuse holder related and clock wiring us now as per diagram. I've also sorted out the map light wiring while I was at it. Thanks.
