#1 Distorted sump
Posted: Fri Feb 27, 2026 4:19 pm
Hi Guys
I was replacing my sump back into position having changed the rings and big end shells. I had difficulty in raising the sump into position whilst keeping the gasket in position. I therefore decided to remove the oil cooler to make the job easier...which it did. The sump went in well and I tightened the sump bolts with no problems and little effort.
However when I raised the oil cooler into position I noticed it wouldn't sit flat but would rock around a high spot which is ringed in the pic. I reckon the high spot is some 3mm high.The perimeter of where the oil cooler sits is flat The oil cooler is flat.
I am at a total loss to understand what is going on.
Anyone have any bright ideas?
regards
David
regards
David
