Hi all,
Quick question: is it possible to check if Stromberg carbs are running rich by lifting the piston and seeing if the engine speeds up continuously like you can with SU carburettors?
Cheers,
Marcus
Stromberg Carburettor mixture check
#2 Re: Stromberg Carburettor mixture check
These downloadable guides from the Forum Knowledge Base tell you everything about Stromberg:
Stromberg Overhaul Guide (74 pages!): https://www.dropbox.com/s/clmwrlgonv8gx ... 2.pdf?dl=1
Stromberg manual (Leyland): https://www.dropbox.com/s/kd8urr3l411dh ... d.pdf?dl=1
Stromberg Needle guide: https://www.dropbox.com/s/domenkpzexkqw ... e.xls?dl=1
Stromberg Strip down by David Lacey: https://www.dropbox.com/s/48pmsd9osrrwi ... n.pdf?dl=1
Pictorial Stromberg strip down guide: http://www.howacarworks.com/fuel-system ... arburettor
#3 Re: Stromberg Carburettor mixture check
Thanks David, I will take a look.
Cheers, Marcus
Cheers, Marcus
S3 FHC BRG
