Vacuum system diagram
ianb
Isle of Man
#1 Vacuum system diagram
Post by ianb » Tue May 12, 2026 4:11 pm
I have a E-Type S3 V12 manual, just finishing a rebuild and desperately need a diagram of the small vacuum hoses that run from the thermo switch to the carbs, intake manifold, distributor etc. any help would be greatly appreciated.
Thank you
lowact
#2 Re: Vacuum system diagram
Post by lowact » Wed May 13, 2026 1:57 pm
There are 5 versions of the thermostatic vacuum system illustrated in the spare parts manual. This copy is in the "E-type Knowledge Base" on this forum:
https://www.dropbox.com/s/xoy273abhzmg1 ... l.pdf?dl=1
Craig Balzer
#3 Re: Vacuum system diagram
Post by Craig Balzer » Wed May 13, 2026 6:11 pm
as colin stated, there are 5 versions of the plumbing for the thermostatic vacuum system.
This photo is of the version that is appropriate for my 72 S3 (UC 1S20954 with engine number 7S7765 SB). Note the post-it that IDs the letter identifiers on the thermostatic vacuum valve. I assume it to be the same of all variations of the thermostatic vacuum system.
Hope this helps
Craig Balzer
Colorado Springs, CO, USA
ianb
Isle of Man
#4 Re: Vacuum system diagram
Post by ianb » Sat May 16, 2026 12:29 pm
Thank you Craig and Colin,
My shop manual has one of the diagrams but not the others, looks like between them I can work it out.
I appreciate the help👍
Ian.
