#1 Adjusting accuracy on Kienzle clock
Posted: Sun Jun 21, 2026 11:03 am
by Busterwebb
Thought I’d have a go adjusting the accuracy of the original Kienzle clock on my S3. So I bought a £10 timegrapher from AliExpress and downloaded the free PC software TG 0.8.0. Rigged up the clock on my desk powered by a 12V battery.
I’ve got it fairly accurate now (approx 30secs/day) but suspect the movement will drift.
(Picture says 25s/day but it drifts around).
Anyway much cheaper than a quartz movement or new clock, and keeps the original.
For those who want to try it:
You’ll need a TGBC timegrapher from AliExpress (or £16.49 from Amazon)
First calibrate with a quartz movement ‘moving hands’ clock
Importantly, Kienzle clocks run at 16200 beats per hour, so you have to over-write the bph display with this figure
Keep sample rate at 44.1KHz and lift angle at 52 degrees.
Clockwise slows the clock. CCW speeds it.
I’ve not measured how far to turn the adjusted for each 60 seconds/day change, but feels like about 20 degrees. Make small adjustments each time and stick a cocktail stick onto your watchmaker screwdriver so you can see how far you turned each time.
Wait 10 minutes after each adjustment for the movement to settle.
Oh btw I’ve read in some chats about removing the clock by dremeling the straps (on later cars that don’t have U clamps). Don’t do that! The clock just pushes out from the back.
Hope all that helps someone.
#2 Re: Adjusting accuracy on Kienzle clock
Posted: Tue Jun 23, 2026 4:12 pm
by Busterwebb
Out of interest, the clock has been reinstalled in the car for a few days now and the accuracy is indeed around 30 seconds per day.
