#1 Brake Pipe Orientation Picture
Posted: Tue Jun 23, 2026 4:36 pm
by andrewk
Can anyone help with a picture of the correct orientation for the solid brake pipe (RH cars) which runs along the front bulkhead i.e. connects the Servo with the Master C33904?
On my car, the pipe sits below the two solid vacuum lines and I believe the correct orientation should be above these pipes. What I'm not sure of is the direction below the wiper motor, is it flush with the bulkhead, or protrudes outwards as indicated in the parts manual?
I have searched on the net, but can't find anything.
Any help is appreciated.
Andrew
#2 Re: Brake Pipe Orientation Picture
Posted: Tue Jun 23, 2026 6:55 pm
by Pete G
Hi Andrew. On my car the pipe in question sits above the two solid pipes along the bulkhead. It protrudes outwards below the wiper motor as shown in your diagram. Directly below the wiper motor the pipe stands away from the bulkhead by about 15mm (thickness of my middle finger) then bends to sit flush on the bulkhead.
#3 Re: Brake Pipe Orientation Picture
Posted: Wed Jun 24, 2026 2:44 pm
by andrewk
Hi Pete,
Thanks for the reply confirming the pipe sits above the vacuum lines and for the information on the direction below the wiper motor - this helps me a lot to get it looking correct.
If you do have a minute or two, I still would appreciate a picture so I know exactly where to make the bends at both sides of the wiper motor.
I'm very much obliged.
Andrew
#4 Re: Brake Pipe Orientation Picture
Posted: Mon Jun 29, 2026 2:49 pm
by andrewk
Hi Pete,
Thanks for your PM, unfortunately no pictures came through - I have replied with my email address, did you receive it?
Kind regards,
Andrew
