#1 Sill Panels
Posted: Sun May 29, 2011 12:50 pm
Hi all,
I have a home made 5 speed conversion which works OK but to get historic registration (meaning real cheap) in my State the vehicle needs to be basically authentic so I will have to take this mod out.
As a result the engine and gearbox will come out and as I want check the rear end I will drop the diff etc - in 40 years it has never been touched.
With those bits out I want to mount the tub via the jacking points on a trolley and do some body work.
So - my question is - with the all the heavy gear moved can I remove one outer sill panel (to replace the inner braces) without bracing the tub up. Only one outer sill panel will be off at a time.
Garry
Garry
