Does anyone know where to buy these or could post a couple of pictures + dimensions for me to make up 2 as I cant seem to find.
appreciated
Nigel
rectangular bent washers for holding on motif bar on S3
#1 rectangular bent washers for holding on motif bar on S3
S3 OTS lavender blue
Hi Nigel,
I hope this answer isn't too late, I suspect the reason you have had no answers is because it is so hard to get photos and measure the washers. Like you I had no idea of the shape of the washers - my car had no bonnet when I bought it.
I made mine and these are the best pictures I could get. I made them from Stainless Steel, about 18 swg which you need for reasonable strength. They are a kind of flat C shape, with a hole for the screw in the back of the washer. The top flange of the C slots into the trough formed behing the grille bars and the lowest one has to be trimmed so the width of the lowest part of the C is just the same width as the motif bar at that point. These are the best photos I could get:
I hope this helps,
I hope this helps,
Series III FHC
Series III FHC
Hi Simon,
much appreciated, it is the little things that seem the most difficult, that's what is so great about the site.
ps your car pics on other post are fab
Hi Nigel,
You are welcome and thanks for the kind comments about my photos, good luck with your own projects!
Series III FHC
Series III FHC
