Exhaust manifold brass nuts
D COUPE
#1 Exhaust manifold brass nuts
Post by D COUPE » Sat Aug 24, 2013 2:38 pm
Avoid with your life.
Driving along and that little exhaust blow creeps up on you.
It gets louder under acceleration but goes away on the overrun.
Its the old cracked exhaust manifold noise again!
After 2 hours stripping the offside of the engine, fiddling like a
arthritic watch maker . the manifolds are OK its the brass nuts
that have come loose (again).
My advice is to fit the modern version metal locking manifold nuts.
Yes I have 20 but I still have 4 hrs to replace the brass ones.
Rather frustrating you know
Dave C
Post by Heuer » Sat Aug 24, 2013 2:44 pm
The fix seems to be Nord-Lock washers: http://www.nord-lock.com/ I used these under the eight nuts at the downpipe joint and they have not come loose. Which metal locking nuts did you use?
D COUPE
Post by D COUPE » Sat Aug 24, 2013 3:09 pm
Hi David The manifold to head studs do not have sufficient thread
to fit a lock or spring washer.
So I am using exhaust manifold nuts with a metal locking rather
than nyloc locking.
DC
Post by PeterCrespin » Sat Aug 24, 2013 9:46 pm
To save confusing our American brethren even further, you worked on the nearside of the engine, not the offside. Which is why referring to the left or right side of the car is universally understood in a way that offside/nearside or driver/passenger side are not.
Post by PeterCrespin » Sat Aug 24, 2013 9:50 pm
Apologies, I read David's post about his exhaust and got mixed up. I assume your car is an S3 with exhausts both sides. Right/left still makes most sense though.
D COUPE
Post by D COUPE » Mon Aug 26, 2013 12:32 pm
I posted in the Series 3 forum only because it is some what of a time consuming job.
Where as on a S1 or S2 it is a hours job and easy considering.
DC
42south
New Zealand
#7 exhaust manifold brass nuts
Post by 42south » Thu Aug 29, 2013 9:12 am
I had the same problem with my S3. One of the brass nuts loosened and eventually the gasket blew out on that cylinder.
What a mission to change the gaskets, hours of lying on my back trying to get small spanners onto the nuts. The rearmost one by the bulkhead was almost impossible, required removing the starter motor, and lower splash shield, for manifold removal and access.
I have since tried to re tighten the brass nuts, but not all are accessible with the splash and heat shields in place.
So what size Nordlock washers are required for the manifold studs? I will use them next time, heaven forbid, if required.
Mark Brown
D COUPE
Post by D COUPE » Thu Aug 29, 2013 7:18 pm
It is actually easier attacked from the top.
Take the bolts out of the engine mounting on the side you
are doing and just jack the engine up an inch.
Splash guard removal is required
DC
42south
New Zealand
#9 brass exhaust nuts
Post by 42south » Thu Aug 29, 2013 8:08 pm
Thanks for that tip.
I hope there isn't another time, but I will certainly try that idea.
Mark Brown
