What is the correct rpm at tick over
Yeldaw
#1 What is the correct rpm at tick over
Post by Yeldaw » Fri May 25, 2012 4:35 pm
Hi does anyone know what the correct rpm that the V12 should tick over at once the auto box is put in drive and when it is in neutral
D COUPE
Post by D COUPE » Sat May 26, 2012 9:48 am
From My own personel expierience. 600 at tick over and 500 when in drive. Just had the rev counter repaired so thats Why Im happy to post!!
I adjusted the tickover up once the new rev counter was fitted as it was a little lower than I thought with a faulty rev counter.
I did not read any books on setting it up I just listened to the engine.
This is only My opinion......................
Yeldaw
Post by Yeldaw » Mon May 28, 2012 10:52 pm
Thanks that is helpful
