Front bumpers and Californian overrides
Sil9090
#1 Front bumpers and Californian overrides
Post by Sil9090 » Sat Jun 16, 2012 8:58 pm
Can anyone tell me what is required to change the USA style bumper and overriders
Sil9090
Sil9090
Post by PeterCrespin » Sun Jun 17, 2012 1:28 am
Depends which end and which year.
The first version just had sprung heavy rubber overriders basically and these can be changed easily enough. I've even seen them just sawn partly off and the reduced rubber chunks look [passably close to the UK/Euro version.
It gets a bit more complex if you have the holes in the bonnet for telescopic rams through the body abutting the picture frame but the real horrors are the humungous rubber block overriders of the last cars. At the back these are mounted to major new pressings welded to the boot floor and you can't just swap for UK parts without significant body surgery.
Sil9090
#3 Front bumpers
Post by Sil9090 » Sun Jun 17, 2012 7:32 am
PeterCrespin wrote:Depends which end and which year.
It's the front bumpers and yes I have the telescopic arms version,do you know the procedure required in this instance
Sil9090
Sil9090
MarkE
Post by MarkE » Sun Jun 17, 2012 10:05 am
I must confess that I thought that all the 'rubber bumper' USA versions on the bonnet had the rams fitted. Mine certainly did; a December '72 car.
The first thing that you need to do is to find a pair of UK spec bumpers and overridders. I found some new-old-stock at the Jag autojumble at Stoneleigh, but that was 10 or so years ago.
The old US spec bumpers and rams just unbolt leaving a hole about 4 or 5 cms in diameter. That just get plated and filled / lead loaded....you can see the extent of the work in the picture of mine being done.
Then just offer up the new bumpers. My new-old-stock ones fitted perfectly, but my car had never had a bump so everything was as per factory. The chances are if you are using repro bumpers or the bonnet has had other repairs in its life, then the bumpers will need to be shaped to fit, and / or the bonnet may need some work to enable the bumpers to fit. That can start to get expensive, hence why I paid more for original bumpers rather that repro.
Alan Proctor did the work, and from memory, the welding / lead loading took 6 hours to complete.
The big job is then the re-painting, as the whole top of the bonnet (at the least) has to be re-finished as there are no swage lines or panel gaps to paint up to from the repaired hole. Just doing the top of the bonnet will work if you have good paint on the wings and the rest of the car, otherwise it will stand out as a repair. My car needed a full bare metal paint job as the Californian sun had burnt it through.
So for me, the job cost less than ?500 for the new bumpers and the metalwork, and ?8000 for the re-paint......but that was the whole car!
And the result is Primrose Perfection!
Sil9090
#5 USA front bumpers
Post by Sil9090 » Sun Jun 17, 2012 9:01 pm
That's great thank you ,I now have a full picture of what's required and your car looks great
Sil9090
Sil9090
